Bilateral filter performance issue
Gang_B_
Hi, ExpertsI had test Bilateral filter in ipp with ippiFilterBilateralGauss and ippiFilterBilateralGaussFast option. But found the performance of ippiFilterBilateralGaussFast is slower than ippiFilterBilateralGauss.
For 1080p 3 channels image on i7-6700k CPU and the latest version of IPP, ippiFilterBilateralGauss cost 10ms to process 1 frame, but ippiFilterBilateralGaussFast cost  500ms to process 1 frame.
Why ippiFilterBilateralGaussFast is slower than ippiFilterBilateralGauss?
Code is as follows:
status = ippiFilterBilateralBorderGetBufferSize_L(filter, size, radius, dataType, channels, distMethod, &specSize, &tmpBufferSize);
status = ippiFilterBilateralBorderInit_L(filter, size, radius, dataType, channels, distMethod, valSquareSigma, posSquareSigma, pSpec);
status = ippiFilterBilateralBorder_8u_C3R_L((Ipp8u*)pSrc, srcStep, (Ipp8u*)pDst, dstStep, size, border, OWN_GET_BORDER_VALP(8u, 3), pSpec, pTmpBuffer);
Gennady_F_Intel
which version of IPP do you use?
Gang_B_
IPP_VERSION_STR "2019.0.2" Windows version.
Did you test the filter before? How about the performance?
Gennady_F_Intel
did you check the status value after each of these function call?
Igor_A_Intel
Hi Gang,
why do you use " ippiFilterBilateralGaussFast"filter type? In the chapter (IPPI manual) devoted to Bilateral filter the only one possible value is described: " ippiFilterBilateralGauss". If you check IPP function status after initialization attempt with " ippiFilterBilateralGaussFast" - you'll see that it is not supported. I'm curious how you've obtained 500 ms per frame if the function does nothing in this case - you should get 0 ms (I guess).
regards, Igor
Gang_B_
Hi, Igor
You are right. I checked the returned value, it's 14.
#define ippStsNotSupportedModeErr          -14 /* The requested mode is currently not supported. */
And actually, it cost 500ms and then return this value.
Intel had defined ippiFilterBilateralGaussFast several years before, when Intel will support ippiFilterBilateralGaussFast?
Igor Astakhov (Intel) wrote:
Hi Gang,
regards, Igor
Gang_B_
hi, Gennady
I checked the status, its -14.
Intel had defined ippiFilterBilateralGaussFast for several years. When intel will implement it?
