Bit Reduction of grayscale 16u to 8u
Battersby__Brian1
I am doing some simple bit reduction of grayscale images from 16u to 8u using ippiReduceBits...
However the resulting 8 bit images do not look very good at all.  What are the best parameters to set for achieving the best looking 8 bit converted grayscale images?
Andrey_B_Intel
HI Brian.
Could you attach images or reproducer, please?
Battersby__Brian1
I was able to get bit reduction working using other API calls in IPP.
Thank you
Gennady_F_Intel
could you give us more details how did you work around the problem?
