Bug in AMR-WB codec
vadim1
I think, i've stumbled on buf in AMR-WB codec in IPP V5.0
In the funciongetBitstreamSize in the file uscamrwb.c
The function calculates the wron number of bytes per AMR frame:
it contains following line:
nbytes = ((BitsLenTbl[usedRate] + 14) / 15) * sizeof(short);
I believe it should be:
a)
nbytes = ((BitsLenTbl[usedRate] + 15) / 16) * sizeof(short);
Or maybe:
b)
nbytes = ((BitsLenTbl[usedRate] + 7) / 8) * sizeof(short);
the b) is equivqlent to what is done in gsmamr (amr narrowband) module.
Vyacheslav_Baranniko
New Contributor II
Thanks a lot!
This is a bug. The bitstream length shouldbe calculated either wayyou pointed out. The bugwill be fixed in thenearest future version of IPP.
Kind regards
Vyacheslav
vadim1
Actually thinkink some more about it
c) is buggy too
the correct code will be:
d)
nbytes = ((BitsLenTbl[usedRate] + 7) / 8);
and b) is faulty too because it will always generate an even
result which is incorrect
Vadim
