6845 Discussions
Bug report: Simple regular expression causing stack overflow in ippsRegExpFind_8u
Wjatschesl_H_Intel
Hi there,
I have a simple example below with which you can reproduce the problem:
#include "stdafx.h"
#include <string>
#include <regex>
#define _IPP_SEQUENTIAL_STATIC
#include "ipp/include/ippch.h"
using std::tr1::regex;
using std::tr1::smatch;
using std::tr1::regex_match;
int _tmain(int argc, _TCHAR* argv[])
 IppStatus status;
 std::string input;
 input += "/*!";
 for (int i = 0; i < 40 * 1024; ++i)
  // random data
  input += 'a' + (i % 26);
 input += "*/";
 const char* pattern = "\\/\\*\\!([\\s\\S]*)\\*\\/";
 // std::regex example
 regex  rx(pattern);
 smatch matches;
 regex_match(input, matches, rx);
 int regExpStateSize = 0;
 status = ippsRegExpGetSize(pattern, &regExpStateSize);
 IppRegExpState* pRegExpState = (IppRegExpState*)malloc(regExpStateSize);
 int errOffs = 0;
 status = ippsRegExpInit(pattern, NULL, pRegExpState, &errOffs);
 IppRegExpFind find[2];
 int numFind = 2;
 status = ippsRegExpFind_8u((const Ipp8u*)input.c_str(), input.length(), pRegExpState, find, &numFind);
 free(pRegExpState);
 return 0;
Is this the expected behaviour or did I miss something?
I also played with RegExpSetMatchLimit. I tried a limit of 2, with that the stack overflow was gone, but it didn't match anything. So this is no solution for me.
Thanks, Slawa
IPP version information
Package ID: w_comp_lib_2016.2.180
Package Contents: Intel(R) Inspector XE 2016 Update 2
Build Number: 450824
Gennady_F_Intel
thanks Slawa, we see the similar results on our side too. We will check the problem and get back asap.
