Bug with IIR filter functions?
pechiinu
Hello.
Please forgive my English.
I am using ippsIIR_32f for filtering audio stream, and have a trouble with this function. When I pass the non-zero samplesto pSrc, the function works well. but when I pass zero samples, the processing becomes delayed.
Why? and How can I avoid this undesirable phenomenon?
Chao_Y_Intel
HI,
Do you have any code that can show this problem? That will be helpful.
Chao
pechiinu
Thank you for your reply, and please excuse me for being late to answer.
I'llgive a samplecode follow:
int iir(void)
int ret = 1;
int const input_length = 48000 * 24;
int const filter_length = FILTER_COEFFICIENTS_LENGTH;
Ipp32f *input = NULL;
Ipp32f *filter = NULL;
Ipp32f *output = NULL;
// zero-padding to input sequence except for the first sample
input = ippsMalloc_32f(input_length);
if (input==0) { goto error; }
for (size_t i=1; iinput = 0;
input[0] = 1;
// set filter coefficients
filter = ippsMalloc_32f(filter_length);
if (filter==0) { goto error; }
for (size_t i=0; ifilter = FilterCoefficients;
output = ippsMalloc_32f(input_length);
if (output==0) { goto error; }
IppsIIRState_32f *ctx;
DWORD start;
DWORD end;
DWORD elapsed;
IppStatus status;
status = ippsIIRInitAlloc_32f(&ctx, filter, (int)(filter_length/2-1), 0);
if (status != ippStsNoErr) {
printf("IIRInitAlloc failure.n");
goto error;
// start measuring
start = GetTickCount();
status = ippsIIR_32f(input, output, (int)input_length, ctx);
// stop measuring
end = GetTickCount();
elapsed = (end-start);
printf("input : time(ms)=%ld status=%dn"
, elapsed, status);
ippsIIRFree_32f(ctx);
ret = 0;
error:
if (input) { ippsFree(input); }
if (filter) { ippsFree(filter); }
if (output) { ippsFree(output); }
return ret;
Thank you.
