6823 Discussions
flow chart of Motion estimation block for intel ipp h.264 encoder
suchethanswaroop
Hi all,
Is there some document where i can find the flow diagram of motion estimation part in intelH264 encoder. The code seems to be confusing as der are many concepts involved at every point. ( like SAD, SATD used, modes used etc)
Thanks in advance
Warm regards,
Suchethan
Chao_Y_Intel
Thanks for the input. The UMC document is considering adding some motion estimation part in the UMC manual. Hope it willprovide some help with your problem.
Chao
suchethanswaroop
Quoting - Chao Y (Intel)
Thanks Chao.
It seems Usage of SATD as opposed to SAD is a flag that can be turned on explicitely in the code. May i know in which function is this flag found ?
Is der an option to do RD search ? its not present in the par file.. if so, where can i turn it on..
Thanks a ton!
Swaroop
Chao
Chao_Y_Intel
Hi, please find some comment from our expert:
SAD is used in ME in speed mode, otherwise SATD. It can be set or unset manually like below:
if (core_enc->m_info.m_QualitySpeed == 0)
core_enc->m_Analyse |= ANALYSE_SAD;
RD is not used in ME, it can only be used in split decisions.
Chao
suchethanswaroop
Thanks a lot Chao :).
Chao
