6847 Discussions
Calculating leftTopBorder and rightBottomBorder for ippiCopyWrapBorder_32f_C1R during wavelet transform
th_weber
I would like to calculate a 2d wavelet transform with a filter tap of length 3 and anchor point 0, more precisely:
lenLow = 3;
lenHigh = 3;
anchorLow = 0;
anchorHigh = 0;
Following the manual at
http://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/ippxe/ipp_manual_win_mac/IPPI/ippi_ch13/functn_WTFwd.htm,
this means I end up with a value of "-1" for rightBorderLow, more precisely:
leftBorderLow = 2;
leftBorderHigh = 2;
rightBorderLow = -1;
rightBorderHigh = -1;
and then
leftTopBorder = 2;
rightBottomBorder = -1;
This means that the later call to ippiCopyWrapBorder_32f_C1R() fails, as I want to add a left-top border of 2 pixels, but the image has only been grown by leftTopBorder+rightBottomBorder=1 pixel.
So, how do I proceed here? IPP is 6.1, but the example code hasn't change for IPP 7.0.
Thomas
Chao_Y_Intel
Hi Thomas,
Wrap border is simple. If you could can not call the function. It may only needs to extendend by yourself. For example,
1 2 3 4 56
is extentend as:
3 4 5 1 2 3 4 5 1 2 3
The data underlined is extended data. A more complex examples on other extenstion can be found here:
http://software.intel.com/en-us/forums/showthread.php?t=78540
Chao
th_weber
Hi Chao,
thanks for your answer. However, my question is more along the lines of whether I'm doing something wrong when choosing an anchor point at 0? And how to calculate the values for leftTopBorder and rightBottomBorder?
Thomas
