6845 Discussions
Can only get black frames from the h.264 decoder.
lycono
Hello all,
I'm trying to integrate the ipp h.264 decoder into our application. I get frame data from an RTP stream. All I can get out of the decoder are black frames (all 0's) where I expect an RGB32 formatted array of bytes. In the debugger the return value from "GetFrame" is UMC_OK, so I assume the decoder was able to decode a frame.
We also use libavcodec (ffmpeg) which seems to work fine, so we're pretty sure it's not bad input data. I've recorded a chunk of video data to a file and played it with the simple_player application. It appears to decode just fine based on the statistics output.
Choice bits of the code are below. Any help is appreciated.
bool ScIppH264Decoder::initialize(int width, int height)
//-- Create video input buffer.
m_in_buf = new UMC::MediaData();
//-- Create output buffer.
m_out_buf = new UMC::VideoData();
m_out_buf->Init(width, height, UMC::RGB32);
m_out_buf->InitAlloc(width, height, UMC::RGB32);
m_out_buf->SetColorFormat(UMC::RGB32);
m_out_buf->SetFrameType(UMC::P_PICTURE);
//-- Create decoder.
m_decoder = new UMC::H264VideoDecoder();
if (m_decoder == NULL)
return false;
UMC::ColorConversionInfo *colorParams = new UMC::ColorConversionInfo();
colorParams->FormatDest = UMC::RGB32;
colorParams->SizeSource.width = width;
colorParams->SizeSource.height = height;
colorParams->SizeDest.width = width;
colorParams->SizeDest.height = height;
colorParams->lFlags = UMC::FLAG_CCNV_NONE;
colorParams->lDeinterlace = 0;
colorParams->lInterpolation = IPPI_INTER_NN;
UMC::VideoDecoderParams *params = new UMC::VideoDecoderParams();
params->m_pData = m_in_buf;
params->cformat = UMC::RGB32;
params->lFlags = UMC::FLAG_VDEC_NO_PREVIEW | UMC::FLAG_VDEC_COMPATIBLE | UMC::FLAG_VDEC_REORDER;
params->lpConverter = new TimedColorConverter();
params->lpConvertInit = colorParams;
params->uiLimitThreads = 1;
if (m_decoder->Init(params) != UMC::UMC_OK)
return false;
return true;
int ScIppH264Decoder::getImage(unsigned char **ptrDecodeImage)
*ptrDecodeImage = (unsigned char*) m_out_buf->GetDataPointer();
return m_out_buf->GetDataSize();
int ScIppH264Decoder::decode(int width, int height, unsigned char *buf, int bufSize, bool *gotImage)
if (!m_initialized)
if (!(m_initialized = initialize(width, height)))
*gotImage = false;
return -1;
if ((bufSize == 0) || (buf == NULL))
*gotImage = false;
return -1;
m_in_buf->SetBufferPointer(buf, bufSize);
m_in_buf->SetDataSize(bufSize);
UMC::Status decStatus = UMC::UMC_OK;
do
decStatus = m_decoder->GetFrame(m_in_buf, m_out_buf);
while ((decStatus != UMC::UMC_NOT_ENOUGH_DATA) &&
(decStatus != UMC::UMC_OK));
if (decStatus == UMC::UMC_NOT_ENOUGH_DATA)
*gotImage = false;
return bufSize;
else if (decStatus == UMC::UMC_OK)
*gotImage = true;
return bufSize;
else
*gotImage = false;
return -1;
