Changing fir filter coefficients at samples rate
Baccouche__Bessem
I'm using a  sparse complex filter for communication channel Simulation. So I have to Change the filter coefficients (so only the values not the positions) at sample rate. So for each filter execution I have to call init function.
It turns out that if I Change the coefficients (using init function) for each sample the calculation is  ca. 100X slower than changing the coefficients for each 500 samples.
Is there a way to reduce the computaional Costs of changing the coefficients?
thank you.
AbhishekD_Intel
We are looking into this issue, and we will get back to you with the updates.
Warm Regards,
Abhishek
Gennady_F_Intel
I am afraid we couldn't help much with the pipeline you describe - this is "by design" behavior.
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
