Color Conversion
karabas
Intel IPP v4.0 mentions RGB565/RGB555 16/15bit color representations.
There are functions which can convert YCbCr to RGB565 and vice versa.
Unfortunately thereare no functions that can convert 24bit RGB/BGR to 16 bit RGB565 by truncation of least significant bits. Orusing zero paddingfor RGB565 to RGB/BGR conversion.It'srelatively easyto implement it.E.g. myMMX/SSE implementation is about 3X faster than optimized C implementation.
I think it's a good idea to add this type of functions to IPPI
Message Edited by karabas on 05-12-2004 09:40 AM
Intel_C_Intel
Thank you for your suggestions. It would be better to submit this as a feature request through the intel premier channel. So, your request will be analized for the planningof future IPP versions.
Vladimir
costelha1
Can't this be done using ippiConvert, ippiScale or ippiReduceBits? If yes, can you give an example for RGB24-->RGB555 and RGB555-->RGB24?
Vladimir_Dudnik
unfortunately such operation can't be effectively done with existing IPP functions
Vladimir
