Compile the IPP Sample with Intel compiler
shincheng
Dear experts
How can I compile the IPP sample code (ex. audio-video-codecs) with the Intel compiler if the compiler is not install at the default location? I try to compile it with the command build32.bat icl110. I got the error message
"ERROR: Compiler "icl110" environment is not found". which part I should modify to compile the sample code??
Thanks for your reply.
Chao_Y_Intel
You can check the file:
ipp-samplestoolsenvsearch_compilers.bat
In the part:
:SET_INTEL_ENV
set COMPILER=icl.exe
set ptn= dir /B /ON "%PrF%IntelCompilerC++%1.*"
@%ptn% 2>NUL 1>&2
if "%errorlevel%"=="0" for /F "usebackq" %%i in (`%ptn%`) do set LASTVERSION=%%i
set ENV="%PrF%IntelCompilerC++%LASTVERSION%%AR%Biniclvars.bat"
if exist %ENV% (
set TOOL=%ENV%
@echo +++ Intel C++ Compiler v.%LASTVERSION% for %AR% is taken
exit /b
echo --- Intel C++ Compiler %ARG% for %AR% environment is not found.
exit /b 1
Change:
to your compile enviroment settings.
Chao
shincheng
Quoting - Chao Y (Intel)
In the part:
:SET_INTEL_ENV
@%ptn% 2>NUL 1>&2
if exist %ENV% (
set TOOL=%ENV%
exit /b
exit /b 1
Change:
Chao
Thanks Chao^^
Vladimir_Dudnik
There should be more elegant way.
To use custom compiler (for example if compiler is not at the default location) you need to set few environment variables:
set CUSTOM=yes
set COMP=icl110
set __EXTERN_TOOL=%COMPILER_HOME%biniclvars.bat
and rerun build32.bat icl110
Vladimir
