6832 Discussions
Conversion : 64f to 32f & 64fc to 32fc and vice versa
rohitspandey
I need to use 64 bit implementation for certain functions in my application for higher precision, but the complete application uses 32f/32fc data types. Are there any conversion functions for like
ippsRealToCplx_64f32Fc or ippsCplxToReal_64fc32f
ie I am able to convert my 32F/Fc vector into a 64f/fc vector or vice versa.
Is there any way to use to achieve this conversion? Kindly let me know the suitable way to implement this.
Rohit
igorastakhov
New Contributor II
Hi Rohit,
use 2-stage conversion for this purpose:
IPPAPI ( IppStatus, ippsConvert_32f64f, ( const Ipp32f* pSrc, Ipp64f* pDst, int len ))
IPPAPI ( IppStatus, ippsConvert_64f32f, ( const Ipp64f* pSrc, Ipp32f* pDst, int len ))
and
IPPAPI(IppStatus, ippsCplxToReal_64fc,( const Ipp64fc* pSrc, Ipp64f* pDstRe, Ipp64f* pDstIm, int len ))
IPPAPI(IppStatus, ippsRealToCplx_32f,( const Ipp32f* pSrcRe, const Ipp32f* pSrcIm, Ipp32fc* pDst, int len ))
Igor
rohitspandey
Thanks !!. But this implementation is slower . Is there any 1 stage conversion
Rohit
igorastakhov
New Contributor II
Rohit,
there are 3 possible solutions:
1) what vector length do you use? I guess (according to your previous posts) 10e4-10e6 - for 64f (and 32f too) it is significantly greater than cache1 size - if you perform all required mathematic in a loop by "frames" of size less than cache1 size - you'll see significant speedup: for modern CPUscache1 size usually is 32Kbyte - it is only 4 K doubles, so I think your "frame" size should be 1 K (you have src, buf and dst - ~3K). This means that you need 2 nested loops - an internal one to perform all operations on 1 K doubles and external one that extends it to 10e4-10e6.
2) you can use intrinsics - if you are not experienced with this stuff - I can provide you a draft of code
3) you can use asm - the same as above - I can provide you a draft
I think that the 1st approach is the most appropriate for you - pipelined execution with taking into account cache size usually has the same performance as special functionality because load/store from/to cache1 is almost for free - ~2 cpu clocks, while for memory case it is ~200 cpu clocks...
Igor
SergeyKostrov
Valued Contributor II
In cases when a big data set of 'float' type, already loaded into memory, needs to be converted
and there are some memory constraints a union based data type conversion could be used. I called it
as a ValueSet based data type conversion. It is not as fast as SSE based with 'ippsConvertxxfyyf'
IPP functions but it doesn't need a second memory block for a data set of 'double' type.
Even if a ValueSet based data type conversion has some limitationsI use itin a couple cases.
For example, a size of data set of 'float' type is 134,217,728 elements and it will use 0.5GB
of memory. A size of data set of 'double' type is also 134,217,728 elements but it will use
use 1.0GB of memory. A total amount of memory needed to complete conversion is 1.5GB.
With a ValueSet based conversion a total amount of memory needed to complete conversion is 1.0GB, that
is, for 0.5GB less!
Please take a look at enclosed example:
typedef union tagFPVALUESET
Ipp32f fValue;
Ipp64f dValue;
inline operator Ipp32f() const { return fValue; };
inline operator Ipp64f() const { return dValue; };
} FPVALUESET;
FPVALUESET FpVs1[_RTDATA_SIZE] = { 0.0 };
// Test-Case 2 - Declared as C Array - 4-in-1 - Unrolled
// RTint -> Ipp32f
g_uiTicksStart = SysGetTickCount();
for( i = 0; i < _RTDATA_SIZE; i += 4 )
FpVs1[i ].fValue = ( Ipp32f )i;
FpVs1[i+1].fValue = ( Ipp32f )i+1;
FpVs1[i+2].fValue = ( Ipp32f )i+2;
FpVs1[i+3].fValue = ( Ipp32f )i+3;
CrtPrintf( RTU("[ RTint to Ipp32f ] [ 4-in-1 ] Converted in : %ld ticks\n"), ( RTint )( SysGetTickCount() - g_uiTicksStart ) );
// Ipp32f -> Ipp64f
FpVs1[i ].dValue = ( Ipp64f )FpVs1[i ].fValue;
FpVs1[i+1].dValue = ( Ipp64f )FpVs1[i+1].fValue;
FpVs1[i+2].dValue = ( Ipp64f )FpVs1[i+2].fValue;
FpVs1[i+3].dValue = ( Ipp64f )FpVs1[i+3].fValue;
CrtPrintf( RTU("[ Ipp32f to Ipp64f ] [ 4-in-1 ] Converted in : %ld ticks\n"), ( RTint )( SysGetTickCount() - g_uiTicksStart ) );
Some Performance results:
Data Size : 67108864 elements
Memory Size: 536870912 bytes
Declared as C Array
[ RTint to Ipp32f ] [ 1-in-1 ] Converted in : 1250 ticks
[ Ipp32f to Ipp64f ] [ 1-in-1 ] Converted in : 704 ticks
[ RTint to Ipp32f ] [ 4-in-1 ] Converted in : 703 ticks
[ Ipp32f to Ipp64f ] [ 4-in-1 ] Converted in : 687 ticks
SergeyKostrov
This is a follow up with a screenshot that demonstrates how ValueSets look like in the VS Debugger:
Theleft 'Watch 1' when a ValueSet was initialized for'float' data type, and the right'Watch 1' when it
was initializedfor 'double' data type.
