6822 Discussions
UIC sample JPEG: meaning of JPEGDecoderParams::SetDCTType
Ryan_Wong
Inside the UIC JPEG sample, (uic_jpeg_dec.h), the classJPEGDecoderParams has the following field:
[bash]ExcStatus SetDCTType(int dctType)
    m_dctType = dctType;
    return ExcStatusOk;
int GetDCTType(void)
    return m_dctType;
[/bash]
However, after careful searching, it appears the field is unused. Is it safe to remove this field? Is there reference to either JPEG specification or IJG documentation regarding the meaning of this field?
Thank you.
SergeyKostrov
Valued Contributor II
1.
It is similar to 'use_qdct' param but due to some reason a consistency was lost. Take a look at
'JPGViewDoc.h' header:
class CJPGViewDoc : public CDocument
void SetDCTType( int use_qdct ) { m_param_jpeg.use_qdct = use_qdct; return; }
2.
In 'JPGView.rc' there is a control 'IDC_USE_QDCT'with a text 'Use fast DCT for not complete blocks'
and it looks like a letter'q' in the 'use_qdct'stands for 'quick'.
Sergey
Sergey_K_Intel
Hi Ryan,
You are right, this field can be safely removed. It might be a duplicate of m_use_qdct data member of CJPEGDecoder class, but abandoned for some reason.
We'll inspect the functions and data members to get rid of unused codes.
Thank you,
Sergey
levicki
I guess that this DCT type parameter was meant to be used to chose whether to use integer or float DCT.
SergeyKostrov
1.
2.
Sergey
SergeyKostrov
Quoting Igor Levicki
It looks like no.
Even ifan integer-based DCT implementations could be done results, compared to float-based
implementations,will be less accurate( roundoff problems ) but they can be calculatedfaster.
Sergey
levicki
I do agree that avoiding floating points today has no speed benefits -- I was just pointing out that IJG has those two modes and similarily named variable.
