Converting an image with n-bit bit depth to a 16-bit bit depth image. (where 8 < n < 16)
KK__Sajas
I need to call the following IPP methods on an input image data.
  • ippiColorToGray
  • ippiLUTPalette
  • ippiScale (just for 16 bit images)
  • ippiCopy
  • ippiSet
  • ippiAlphaComp
I was using the 8-bit and 16 bit versions of this methods till now. But now we also allow 12 bit images as input. For ippiLUTPalette, I see that we can pass the bitSize that we are dealing with. But for the other API's we don't have it.
One approach I was thinking of trying out was to convert the images that has a bit depth falling between 8 and 16 bit to a 16 bit image and continue working on the result. I believe, ippiScale performs such conversions. But I couldn't find a flavor of it that works on bit depths other than 8, 16 & 32.
Is there a way to perform this conversion?
Or Is it possible to call the before mentioned APIs on images with bit depths other than 8 and 16 bits?
Chao_Y_Intel
Hi Sajas,
How are the 12-bit image data stored now?   Are they just stored as two-bytes of data, and ignore the high bit?  or  are they stored in other ways?
thanks,
Chao
