6815 Discussions
Convrt/ReduceBits 8u1u rotate content of resulting byte ?
Aris_Basic
is there a simple way of rotating content of resulting byte of hose functions ? (bit 7 becomes 0 ... 0 -> 7 etc)
Edit:
maybe reversing bit order is more appropriate name
Ying_H_Intel
Could you give a sample to show the functionality, for example, the input data type and size, the output date type? Convert_8u1u or ReduceBit 8u1u just convert, no rotate
If shift by bit, intel compiler's intrinsics function seems be able to do this. for example
unsigned int _rotl(unsigned int value, int shift)
Implements 32-bit left rotate of value by shift positions.
unsigned int _rotr(unsigned int value, int shift)
Implements 32-bit right rotate of value by shift positions.
Intrinsics for IA-32 and Intel 64 Architectures
unsigned short _rotwl(unsigned short value, int shift)
Implements 16-bit left rotate of value by shift positions.
unsigned short _rotwr(unsigned short value, int shift)
Implements 16-bit right rotate of value by shift positions.
Ying H.
SergeyKostrov
Valued Contributor II
Quoting Aris Basic
Edit:
A lookup table of 255 reversed bytes.Speaking about performance nothing would compare with it.
Sergey
SergeyKostrov
This is a follow up and a genericexample provided:
const int iSize = < some value >;
unsigned byte ubData[ iSize ] = { 0x0 };
unsigned byte ubLUT[ 256 ] =
//Lookup Table ( LUT )of 256 unsigned bytes initialized with the bit reversed values
// ubData initialization / usage code / etc
for(inti = 0;i <iSize; i++ )
ubData = ubLUT[ ubData ];
Sergey
