Core2Dual vs. Celeron -> Calculationtime!?!
gregsch
Hi!
I'm still working on a IPP-performance Test..
In this case I checked some division functions.
(look at the following code example.)
The compiling mode was "singlethreaded". The executable Programm
was checked on a Celeron and a Core2Dual processor.
The dual processor takes 83 microsec calculationtime, the Celeron
takes 9microsec calculationtime.
(In Multithreading-mode Core2Dual takes 4 microsec)
Can you explain the matters (83microSec???!?!!) of this
effect to me?
Is there any possibility to increase the dualcore
calculation time?
Thanks-Gregor
#include
#include
"Windows.h"
#include
"conio.h"
#include
"ippcore.h"
#include
"ipp.h"
#include
"ipps.h"
#include
"ippi.h"
#include
#include
#include
"ScopeTimer.h"
void
main( void )
try
int num=
1024;
Ipp8u
* ippsptrsrc1 = ippsMalloc_8u(num);
Ipp8u
* ippsptrsrc2 = ippsMalloc_8u(num);
Ipp8u
* ippsptrdst = ippsMalloc_8u(num);
ippsSet_8u
100,ippsptrsrc1, num);
ippsSet_8u
100,ippsptrsrc2, num);
IppStatus tempIppStatus
= ippsDiv_8u_Sfs(ippsptrsrc1, ippsptrsrc2, ippsptrdst, num, -
1);
if(tempIppStatus!=ippStsNoErr)
throw std::string(ippGetStatusString( tempIppStatus));
double dt=
0;
ScopeTimer timer
(dt);
ippsDiv_8u_Sfs
1);
ippsFree
(ippsptrsrc1);
ippsFree
(ippsptrsrc2);
ippsFree
(ippsptrdst);
std
::cout<<
"calctime "<< dt<<" mikroSec"<<std::endl;
//try
catch( std::string& e )
std
::cerr << "String exception: " << e << std::endl;
catch( ... )
std
::cerr << "unhandled exception" << std::endl;
getch
class
ScopeTimer
public
ScopeTimer
(double& outmicrosecs) : microsecsElapsed_(outmicrosecs)
QueryPerformanceFrequency
(&frequency_);
QueryPerformanceCounter
(&countStart_);
~ScopeTimer()
(&countStop_);
const double countDif
= static_cast< double >(countStop_.QuadPart-countStart_.QuadPart);
microsecsElapsed_
= static_cast<int>((1000000*((double)(1.0/(double)frequency_.QuadPart))*countDif)+.5);
private
double& microsecsElapsed_;
LARGE_INTEGER countStart_
LARGE_INTEGER countStop_
LARGE_INTEGER frequency_
Vladimir_Dudnik
what do you mean exactly when saying single thread mode or multithread mode?
InIPP 5.3.1 we provide DLLs which are threaded inside, static libraries which are not threaded and static libraries which are threaded. Which libraries did you use? What compiler did you use to build your test?
In any case, it is dangerous to link in single thereaded application modules which are threaded, there are important differences in C run time which may cause issue.
Vladimir
gregsch
Hi! Saying single thread mode or multithread mode means the usage of Runtimelibraries in the Project.(ProcectProperties->C/C++->code assembly->Runtimelibraries(Multithreaded/Singlethreaded)). Im using visual C++ Version7.1.30.88(2003).
Im confused about the increasing of calculating time.Multithread isdisabled.Why does the dual core machine take such a long time according to the Celeron machine (approx. FPU or similar isretarded??)Especially the division operations show this effect?! Other threaded functions result a expectet calculating time.
Regard, Greg
PS.: I can send a calculating time analysis, showing this effect.
Vladimir_Dudnik
As I've saidin previous post, itis incorrect to link multi-threaded libraries (I assume you link with IPP DLLs) and single-threaded run-time libraries in one executable.
You'd better link with IPP not-threaded static libraries if you need really not-threaded application.
Vladimir
gregsch
Hello!
Another question in this case:
I want to use only one core on my Dualmachine. The seond core
should be unused.
The first lines of my main
programm(see above) look like this:
DWORD processorBitMask = 3;
BOOL success = ::SetProcessAffinityMask(::GetCurrentProcess(), processorBitMask );
SetProcessPriorityBoost( ::GetCurrentProcess(), TRUE );
I'll do a multithreaded linking.
Now my System shoult use only one of the two cores for my division.
So the expectet calculationtime should be anything like on a one core
System(for example Celeron = 9microsec).
But the calculationtime takes also somthing like 84 mircosec...
Why does the Calculation take such a long time?!
Greets Gregor
Ivan_Z_Intel
IPP is based on OMP that knows nothing about your manipulations with thread affinity. If you want to run your app (IPP) in one thread - use specialy intended for it function - ippSetNumThreads(1), please.
#include
#include
"Windows.h"
#include
"conio.h"
#include
"ippcore.h"
#include
"ipp.h"
#include
"ipps.h"
#include
"ippi.h"
#include
#include
//#include "ScopeTimer.h"
class
ScopeTimer
public
ScopeTimer(
QueryPerformanceFrequency(&frequency_);
QueryPerformanceCounter(&countStart_);
~ScopeTimer()
QueryPerformanceCounter(&countStop_);
const
double countDif = static_cast< double >(countStop_.QuadPart-countStart_.QuadPart);
microsecsElapsed_ =
private
double
LARGE_INTEGER countStart_;
LARGE_INTEGER countStop_;
LARGE_INTEGER frequency_;
void
main( void )
try
int
num= 1024;
Ipp8u* ippsptrsrc1 = ippsMalloc_8u(num);
Ipp8u* ippsptrsrc2 = ippsMalloc_8u(num);
Ipp8u* ippsptrdst = ippsMalloc_8u(num);
ippsSet_8u(100,ippsptrsrc1, num);
ippsSet_8u(100,ippsptrsrc2, num);
ippSetNumThreads( 1 );
IppStatus tempIppStatus= ippsDiv_8u_Sfs(ippsptrsrc1, ippsptrsrc2, ippsptrdst, num, -1);
if
throw
double
dt=0;
ScopeTimer timer(dt);
ippsDiv_8u_Sfs(ippsptrsrc1, ippsptrsrc2, ippsptrdst, num, 1);
ippsFree(ippsptrsrc1);
ippsFree(ippsptrsrc2);
ippsFree(ippsptrdst);
std::cout<<
"calctime "<< dt<<" mikroSec"<<:ENDL>
int
numThr;
ippGetNumThreads(&numThr);
//try
catch
( std::string& e )
std::cerr <<
catch
std::cerr <<
getch();
The result of this code executionon Core 2 Duo machine is 5 - 7 microSec.
IZ
