6847 Discussions
Does the AACEncoder support the source with resolution higher than 16bit?
Richard_X_
I read a comment in the sample App of audio_codec_con in the encoding section
/* we should transform 24 and 32 bits input to 16 bits one */
before calling the AACEncoder.
Does this mean the encoder cannot support higher resolutions like 24bit or 32bit? Thanks.
Richard_X_
ACEncoder
::GetInfo(BaseCodecParams* info) hard-coded the resolution as
pAudioCodecInfo
->m_info_in.bitPerSample = 16;
Why?
Vladimir_Dudnik
IPP AAC encoder currently does not support resolutions bigger than 16 bit. We do not see additional advantages from that functionality, do you?
Vladimir
