Corrupt JPEG Output
turks
Using Picnic in the IPP 6.0 update 1, if you open the attached bmp file and save as jpeg using the settings :
Bas, 444, Use Huffman, RGB, quality=75
The resultant jpeg file will be grayscale and distorted.
Can you reproduce ?
Sergey_Ryadno
Quoting - turks
Can you reproduce ?
try to change in jpeg.cpp in functionSaveImageJPEG() this line
dataOrder.LineStep() [0] = geometry.RefGridRect().Width() * nOfComponents * du;
to this
dataOrder.LineStep() [0] = image.Step();
