vesion 6.0.1 slower than 5.1
delalaym
We were using the 5.1 version on our application. In that library, as far as I know, there was no optimization for the Core 2 Duo.
We are now trying the 6.0.1 version and it is slower then the 5.1 even though he now detects that I have a Core 2 Duo... How is that possible? The function that we use that takes the most CPU is : IppsMulc_32s_sfs
I've done also the performance test with ps_ipps.exe on both 5.1 and 6.0.1 and effectively, it sometimes takes longer on 6.0.1...
Any Idea?
Vladimir_Dudnik
How did you test the performance? Please note it may depend on the data you use. For example supplying NANs you will definetely drop the performance down.
Vladimir
Ying_S_Intel
Quoting - delalaym
Any Idea?
Can you verify that what Intel IPP optimized libraries are loaded respectively from versions 5.1 and 6.0.1 on a Core 2 Duo? A simple way is to run ps_ipps.exe from /tools/perfsys from 5.1 and 6.0.1 folder and tell us what the outputs from first several lines, the data could help us understand the IPP optimized code used in these 2 versions.
Ying
delalaym
Quoting - YING S (Intel)
Ying
I have attached a file. It contains a run for the ippsMulC_32s_Sfs function on both 5.1 and 6.0.1. It seems like the 6.0.1 is slower...
thanks.
pvonkaenel
New Contributor III
Quoting - delalaym
thanks.
One possible difference could be if you're statically linking and using the threading layer in 6.0.1 (was not available in 5.1). Are you using the same linking/threading model in both tests?
Peter
delalaym
Quoting - pvonkaenel
Peter
Yes, I am using the same thing...
Marc-Andre
pvonkaenel
New Contributor III
Quoting - delalaym
Marc-Andre
Since you have pretty good documentation about the slowdown, and it looks like you might even have a timing application that demopnstrates it, you might want to create an Issue in Premier support. I found a similar slowdown in the template matching migrating from IPP 4.1.3 to 5.? for a certain CPU. I submitted the information and they were able to fix the problem.
Peter
