Cumulative Sum
thorsan1
Hi
I need to compute the cumulative sum of a 1D signal. In C it would look like
for(int k=0;k...)
A += A[k-1];
How can this be done using intrinsics and/or IPP?
Thanks for any help
Vladimir_Dudnik
As I remember there was a similar question regarding 2D operation, you can see thread
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=980
regarding piece of code you shown, is it exactly what you mean? This code will read data from outside of available memory for k=0.
We do not have similar functions in IPP. You can take a look on ippsSum function family, which calculate sum of all elements in 1D vector
Vladimir
Intel_C_Intel
Hi!
IPP has function ippiIntegral that calculates the image integral on the rectangular area. If you call it for the image with 1 row you get the cumulative sum
Alexander
thorsan1
hi
thanks for the help.
ok. there was an error in the kode the loop should go from k=1...
Ill take a look at the integral function. but does anyone know how it is done?
thorsan
Intel_C_Intel
Imageintegral function maps input NxM image to output (N+1)x(M+1) image. It calculates dst[n,m]=SUM(src[i,j]), i
For more details see IPP Manual Image processing
Alexander
