Custom DLL: No DLLs found in Waterfall procedure
Deleted_U_Intel
Hello.
We've purchased IPP for Windows. I've build the Custom DLL exactly as it is described in the sample, I've only changed names of functions in export.def and funclist.h. The DLL and LIB created just fine (totally about 80 functions are needed from IPP).
Then, I create my own DLL which is linked against custom IPP lib.
Then I link my application with my own DLL. Totally I have an application .exe, my DLL's .dll and IPP custom .dll - in one folder.
But when I try to execute it on machine without IPP runtime support installed, I get the message cited in $SUBJECT. On machines with IPP runtime everything runs OK.
Whatshould I do now? I'd like to reduce the size of application I'm building but can't do that since Custom DLL doesn't work for me.
Please assist.
Thanks in advance.
Vladimir_Dudnik
Hi
to answer your question we need to see:
-how you call linker to make your custom DLL
-how you call linker to make your own DLL
-how you call linker to make your application
It seems somewhere you still link original IPP libs
Vladimir
Message Edited by vdudnik on 11-29-2004 05:45 AM
Vladimir_Dudnik
Hi Alex,
I'm glad that you found solution!
I'll ask appropriate people about license question you have.
Spasibo za interes k IPP:)
Vladimir
