custom video interpolation using IPP
andrewk88
I need to perform a very special type of video interpolation which produces 2x larger 2D block of video data in floating point format.New pixels in an upscaled both horizontally and vertically image should be a sum of neighbors and original pixels values should be preserved in interpolated image as well. That operation for a single row of 2D data block might be illustarted as follows:
1 3 5 7 ----> 1 4 3 8 5 12 7 7
After all rows in 2D block are interpolated that way, I need to do the same in vertical.
I don't see a good fit in IPP library for such custom processing, so I'd appreciate any suggestions.
Andrew
borix
that is not interpolation
interpolation (several types) can be done by the resize function
andrewk88
Yes, that's right ...and let's say I still want to do what I have planned.
Any hints ?
Andrew
