DV Decoder Sample
michaeldvornikov
I see small white dots around bright and contrast parts of the image such as subtitles. I think DV decoding tables are not implemented correctly in the IPP sample.
The tables aredescribedin the Sony DV/DVCAM specification
Intel_C_Intel
They have forgotten all the 15 bits codes in dvTable2[]. You should be able to get these from huffman.c in the dv-encoder sample.
Anyway, this code is so messy that youd better start from scratch..
carlr
The sample provided is more or less unusable, unfortunately. Most of the samples, even if not a robust implementation, provide a good starting point. This is not one of them.
