DV100 720p
arvinzchan
Hi, I am having a problem decoding DV100 720p. Every even frame is shifted up a 1/4 frame. The decoder works for 1080i. Is there some variable I am not setting correctly?
Thanks in advance,
Arvin
Vladimir_Dudnik
Hi Arvin,
there is comment from our expert:
That situation will happen if you call GetFrame() method without initialization of codec. Please check that the codec is initializedwith the following variables:
m_System = System720_60p;
m_nSystem720_LastDecodedChannel = 0;
m_nWidth = 1280;
m_nHeight = 720;
(They are needed for DV00_720p decoding)
Vladimir
arvinzchan
Hi Vladimir,
Thanks for getting back to me. Turns out I was initializing the codec correctly. I was setting the width x height to 1280x720 so it does recognize the video as 720p.
The problem turns out to be in GetFrame() itself. I fixed the issue by not changing m_nSystem720_LastDecodedChannel = 2
if(m_System == System720_60p)
//if(m_nSystem720_LastDecodedChannel == 0)
// m_nSystem720_LastDecodedChannel = 2;
//else
Commenting out the above code in GetFrame() fixed the problem for me.
Regard,
Arvin
drastic
Hi All
I have the exact same shift with DV100 720p60 decode using the 5.3 IPP and latest ipp-samples. I made sure I was setting the codec up properly and tried commenting out the lines above, but no luck. DV25/50 and 1080i100 are all fine, just the 720p. Any other suggestions?
James
drastic
I guess another, more popular question might be, is anyone else seeing this problem in the 5.3 version of IPP?
Thanks, J
Vladimir_Dudnik
there is common recomendations from our expert:
1. method Init should be called before GetFrame
2. variable m_nSystem720_LastDecodedChannel should be set to 0 (zero) at initialization.
Vladimir
