Decode Mpeg2 Intra-Slice
Atsushi_S_
Hello.
I try to develop mpeg 2 decoder with Intel IPP.
I want to decode Intra-Slice(P-Frame only) mpeg2 stream with it.
I use UMC::MPEG2VideoDecoder(Intel IPP Sample ver 7.1.1.013) for it.
But, if i try to decode, UMC::MPEG2VideoDecoder always return VM_NOT_ENOUGH_DATA.
So, I have question, Is it possible to decode Intral-Slice mpeg2 frame with it ?
If it posslibe, how can I decode it ?
Please advice to me.
Thank you.
Chao_Y_Intel
Have you got the chance to check Intel MKL SDK product?  Because Intel IPP UMC example is the legacy code, and there is no active development now.
Chao
Atsushi_S_
Hello, Chao Y.
Thak you for your reply.
Intel MKL SDK is Intel Media SDK ?
I try same things with Intel Media SDK 2014 R2 for Client.
But result is same.
I could'nt decode Intra-Slice Mpeg2 stream with Intel Media Sdk.
I make mistake in setting or same thing ?
Or is it impossible to decode Intra-Slice Mpeg2 stream with Media Sdk ?
Please let me know.
Thank you.
