Directx and IPP
vindos
hi guys,
I am currenly working on directx. After rendering i need to store each frame into the memory and when the application exits i dump that datainto the disk in the form of jpeg.
For this iread data from back bufferand use memcpy to store it into the memory,My doubt is whether i can compress the backbufferdata using this library and then store it in to memory.
tnx in advance
Vladimir_Dudnik
you can consider your backbuffer just as usual image. The only point you need to keep in mind is pixel format of your data. The JPEG standard specifies only 8-bit per color channel process for baseline mode. Soif you are working with RGB565 data you need to convert them to RGB888 before applying JPEG compression. Please take a look on JPEGView sample it contains IPP JPEG codec with simple interface so you might be can use it in your app.
Vladimir
Message Edited by vdudnik on 01-12-2006 12:29 PM
