6814 Discussions
Does IPP5.1 works without using MFC applications ?
zijia15
i have 2 applications, 1 using MFC and 1 just a normal winCE application both trying to do the same thing:
Ippisize = {100, 100};
unsigned char *rawImage = new unsigned char[height*width];
IppiImageJaehne_8u_C1R(rawImage, width, size);
For the winCE application, i do this in WINMAIN.
When i check the rawImage using debug, it is blank. However for the MFC application, it is working corrctly.
Can someone advise me ?
Thanks !
Vladimir_Dudnik
if there is no output from IPP function call it is very probably that function returned with error code by some reason. If you will check a return code from function you might see what the problem. It is better to take it as a rule:)
Vladimir
