Don't support the h264 decoder frame-by-frame?
relay21
I want for h264 decoder to operate frame by frame reading of data by our application.
But, the h264 decoder in simpledecoder.cpp operatein a file.
This sample code is welloperatedin a file.
But, in frame by frame operation, GetFrame()method returns UMC_ERR_NOT_ENOUGH_DATA infinitely.
Ying_H_Intel
Quoting - relay21
Hello
here are some discussion for your reference,
1) http://software.intel.com/en-us/forums/showthread.php?t=68676
GetFrame()willdon't start decode (returnUMC_ERR_NOT_ENOUGH_DATA) untill the decodebuffer is full. So you may consider add some loop wrapper to thefucntion GetFrame(). Once it returns data (start decode), you will get data frame by frame
2) or eliminate the delay by the way in
http://software.intel.com/en-us/forums/showthread.php?t=67755
But please note only work with no re-ordering (decode order = present order),
Hope it helps
Ying
