Echo and echo level
harald85
Hi
I want to use the EC in the kernel mode but the echo has an higher level then the normal signal so I have to decrease the level of the echo. Is there any possibility to do that with the IPP oder did somebody know how i can change the level of an Signal (16 Bit 8KHz)?
Harald
Vyacheslav_Baranniko
New Contributor II
Quoting - harald85
Hi
Harald
Hi
Prior to playing a far end signaloutyou maynormalize it by usingIPP ALC (audio level control) functions:
ippsALCGetStateSize_G169_16s - reports the size of the state memory required for AC algorithm,
ippsALCInit_G169_16s - initializes the state memory of required size allocated by user
ippsALCSetLevel_G169_16s - setstarget (desired)and clipping level in dBm0(with sign dropped).
ippsALCSetGain_G169_16s - sets gain whichcontrols output signal level change rate vsinput. 0 - mingain.
ippsALC_G169_16s - performs ALC.
Vyacheslav, IPP, Speech coding
harald85
Hi
The function works very well. I use it with the parameters:
ippsALCSetLevel_G169_16s(6.f, 6.f, pALCState);
ippsALCSetGain_G169_16s(0.f ,pALCState);
But know the level is too low. In which function and with which parameter can i choose the level of the file?
Harald
Quoting - vbaranni
Hi
harald85
Hi
I changed the parameters for gain and level but the result is always the same. With level 6.f and gain 0.f is the result to low and the Nr clears the signal. So which parameter must I change to increase the level of the result?
THANKS
Harald
Quoting - harald85
Ivan_Ryzhachkin__Int
Quoting - harald85
you may try the lower levels. For exampe:
ippsALCSetGain_G169_16s(0.f ,pALCState); //ippsALCSetGain_G169_16s - sets gain which controlsoutput signal level change rate vs input. 0 - min gain.
ippsALCSetLevel_G169_16s(2.f, 2.f, pALCState);//ippsALCSetLevel_G169_16s - sets target (desired) and clipping level in dBm0 (with sign dropped).
Ivan R
