Error in documetation of color conversion
gilgil
I am using intel compiler 11.1.054 and I have the ippiman.pdf of march 2009. In page 273 there is "Example 6-1 Using the Function ippiRGBToYUV".
The example returns error due to wrong roi size. it should be {3,3} and not {9,3).
Is it a bug in the compiler or the wrong documanetation ?
Gennady_F_Intel
This is the wrong example. roiSize should be {3,3}.
This issue has been submitted to our internal development tracking database for further investigation, we will inform you once a new update becomes available.
Here is a bug tracking number for your reference: DPD200186071.
--Gennady
Gennady_F_Intel
I think, this code would be much better:
#define nChannels 3
int main() {
Ipp8u src[3*3*nChannels] = {
255, 0, 0, 255, 0, 0, 255, 0, 0,
0, 255, 0, 0, 255, 0, 0, 255, 0,
0, 0, 255, 0, 0, 255, 0, 0, 255};
Ipp8u dst[3*3*nChannels];
IppiSize roiSize = { 3, 3 };
IppStatus st = ippStsNoErr;
int srcStep = 3*nChannels;
int dstStep = 3*nChannels;
st = ippiRGBToYUV_8u_C3R ( src, srcStep, dst, dstStep, roiSize );
if ( st == ippStsNoErr){
printf("\n ************* passed ****************\n");
}else{
printf("\n ************* failed ****************\t");
return 0;
--Gennady
gilgil
This solves the problem.
