Hi.
What is the operational system?
What software did you use to compile IPP examples?
Thanks a lot for your reply. I am honoured. As of now, i am successful in getting some output from the Echo Canceller sample that is provided in Intel IPP speech coding sample. The input to that sample is supposed to be 3files as command-line arguments. i.e.
usc_ec[options]
where,
r-inPCMFile and s-inPCMFile files processed to perform echo path parameter estimation and estimated echo is subtracted from s-in sample and echo-free PCM data is written to s-outPCMFile file.
My problem here is i got the output but in a strange way. i.e. when i executed the program with proper parameters (where my r-inPCMFile and s-inPCMFile files were the outputs of a telephone conversation), i got s-outPCMFile with one of the voices missing in the conversation and that voice was replaced by a bad disturbance. Echo was never removed.
I would be glad if you help me on this. I use Fedora Core-III and gcc to compile IPP programs.
Is your OS in the list of supported OS?
Another question - did you try to use different algorithms in your work?
[-a
Was the result the same withdifferent values of options?
Vladimir Dudnik, can you help in this question?
If not can you suggest some different files where i can test the echo removal?
Any mails regarding the same to me ( suvidya2000@gmail.com ) will be appreciated.
Suvydia
Can you please attach your r-in and s-in files so I can play with them?
Make sence also to decrease R-IN level, thus to lessenthe echo replica inS-IN. Also, an echo level is desired to belower thana talker voice.That is, before r-in and s-in files recording, nice todecrease a speaker volume.
Slava
Cite: ITU G167 5.2.2.2 Signal levels:
The tests described in the sequel apply to level signals between [30 dBm0] and [10 dBm0] at Rin, and acoustic signals with levels 4.7 dBPa [ 10 dBPa] at Sin
Slava.
I used IPP vocoders in my work. We could share our IPPexperience if you don't mind.
My email: pseudor@yandex.ru
I would be the happiest. I am sending you the files right away on your above mention e-mail address.. Which operating system do you work on?
I work under Windows XP Prof. and Linux ASP 11.
