FFT in IPP only takes dimension as power of 2?
missing__zlw
Is this true? If so, why? It is not very convenient for only have FFT with dimension as power of 2.
MKL supports other dimensions numbers.
Naveen_G_Intel
You are right, IPP supports transform size is power of 2 only. Refer to IPP and MKL Choosing a High Performance FFT.
Naveen Gv
Vladimir_Dudnik
you should be able to use IPP DFT functions. They do support non power of 2 length.
Vladimir
