Field copy with Alpha
BatterseaSteve
Hi
I have a question
I have a source buffer of interlaced, interleaved YUV with alpha
i.e. UYAVYA - 1920x1080
I need to strip the alpha, extract one field, resize it to half and convert to 420planer
as a single buffer (i.e not 3 separate planes but a single buffer of concatenated Y,U,V
Can anyone recommend the fastest set of methods to do this?
Cheers
Steve
BatterseaSteve
The main problem I have with this is actually the alpha strip. i.e. getting the UYAVYA into UYVY.
I tried the following:
IppiSize uyvyRoi = {1,1920*1080};
this->uyvyBuffer = ippsMalloc_8u(1920*1080*sizeof(Ipp8u)*2);
ippiCopy_16u_C1R((Ipp8u *)uyavyaBuffer, 3, this->uyvyBuffer, 2, uyvyRoi);
but this is incredibly slow (15msec!)
I am struggling to find anything else that will strip a single channel from a 3 channel image, or copy a 3 channel image to a 2 channel image.
Any help appreciated.
Steve
Sergey_K_Intel
Hi Steve,
For stripping alpha channel values you can probably use ippiSwapChannels_8u_C4C3R function. There's dstOrder[3] array, specifying the order of output channels.
Sergey
Igor_A_Intel
Hi Steve,
as finally you need planar format - you can try to use ippiCopy_8u_C4C1R 3 times - for Y, U and V
regards, Igor
BatterseaSteve
Hi Sergey
Thanks for responding. As far as I can tell, the ippiSwapChannels_8u_C4C3R will only swap 4 component to 3 component - I need 3 component to 2 component.
Cheers
Steve
BatterseaSteve
OK
I have most of this worked out - except the alpha strip
As I said above, i can use ippiCopy_16u_C1R - but this is taking a long time - 15msecs
Can anyone tell me why?
Cheers
SergeyKostrov
Valued Contributor II
>>As I said above, i can use ippiCopy_16u_C1R - but this is taking a long time - 15msecs >> >>Can anyone tell me why? You didn't tell us anything about hardware, that is CPU, and my question is do you use a right CPU Dispatching DLL for Image Processing domain?
BatterseaSteve
Hi Sergey
Thanks for replying
CPU is E2660, machine is z820 dual CPU 32 cores. So no slouch! Running g windows 7 64 bi
Compiled on vs2010 64 bit
As far as I know I am using auto dispatching.
I will check though.
SergeyKostrov
Take a look at Intel® Integrated Performance Primitives for Windows* OS User's Guide: ... Page 19 Intel® Integrated Performance Primitives Theory of Operation Dispatching ... There is a table Identification of Codes Associated with Processor-Specific Libraries.
BatterseaSteve
Hi Sergey
I run ippInit since I am using static Libs
I check the cpuType from ippGetCpuType and it returns ippCpuAVX which is correct for my CPU I think.
Cheers
Steve
BatterseaSteve
Hi Digging a bit deeper reveals the problem to be due to the stepSize I am using.
If I run:
ippiSize uyvyRoi = {1,1920*1080};
uyavyaBuffer = ippsMalloc_8u(1920*1080*sizeof(Ipp8u)*3);
ippiCopy_16u_C1R((Ipp8u *)uyavyaBuffer, 3, uyvyBuffer, 2, uyvyRoi);
I get anything from 7-15msecs.
If I run:
ippiSize uyvyRoi = {1920,1080};
ippiCopy_16u_C1R((Ipp8u *)uyavyaBuffer, 1920*2, uyvyBuffer, 1920*2, uyvyRoi);
I get 0.2msecs......
So the point is that trying to strip the alpha by treating the source buffer as a 3x(1920x1080) buffer and the dest as a 2x(1920x1080) buffer is bad. Which puts me back to square one...... Anyone got any other ideas - 'cause I can write a c loop thats quicker.
Cheers Steve
Igor_A_Intel
Hi Steve,
as I've already answered - you should use ippiCopy_8u_C3C1R 2 times (as finaly you need planar format) - this F extracts any channel you need from C3 image (so C4C1 - the same but for C4 image)
regards, Igor
BatterseaSteve
Hi Igor
Thanks for replying and sorry - I did see your comment before and thought I had replied.
The problem with ippiCopy_8u_C3C1R is that it extracts the UYA VYA image into Y's and UV's.
I tried this as you suggested but I need the Y's the U's and the V's in separate buffers.
So the question remains as to how I extract the UV's into separate U and V buffers?
I have looked at the format conversions to see if there was one that would take NV12 422 and convert to YUV420p but I could not see one.
I've been on this a week now and am now delving into trying to use SSE!
Any thoughts gratefully received?
Cheers
Steve
BatterseaSteve
Hi
I solved this using a bit of bespoke SSE to split the UV buffer into separate U and V buffers.
Total time seems acceptable.
Cheers
Steve
