Find clusters of integers?
Richard_Lindberg
Hi, I'm interested in some functions that I cant seem to find in IPP. I dont know if it's the correct place to look for these either. I'm probably not using the correct mathematical terms now, but I think you'll see what I mean.
1. Im interested in a function that can find coherent clusters of integers in an integer vector or matrix. That is I have a vector with numbers [0, 0, 0, 1, 1, 1, 1, 2, 3, 3, 2] and I have the integer 1 and a threshold of 2. I would like to find the clusters of ones larger than 2 items in above vector.
2. I would like to be able to create a mask vector or matrix from a scalar number. I have a vector [0, 1, 2, 3, 1, 1, 2, 1] and a scalar 1. When calling this function I would like it to return the vector [0, 1, 0, 0, 1, 1, 0, 1].
3. I want to use the above mask vector or matrix of zeros and ones and apply a function to all elements of another vector at the indices of the ones in the mask vector.
Is any of the above cases supported in these libraries?
Best regards
Richard
Ying_H_Intel
Hi Richard,
It seems noobvious IPP function which can for such kind of operation. Can i understand the operation isfrom data mining?is these operation related to a some known algorithm for example, Haar classifier, watershed image segmentationetc.
Just share some i can suggest,
1) the operation is like image segementation. what's output you may check IPPi manual and see computer vision section. The operations may becompleted by ippiThreshold_LT, or ippiLabelMarkers.
2)seems use ippiThreshold_x or ippiThreshold_LTValGTVal can do this
3) some of ipp function support Mask operation. for example,ippiCopy , which can copy one array to another arrayaccording to theMask (0,don't copyand 1 copy) .
Operation on masked pixels only
IppStatus ippiCopy_(const Ipp* pSrc, int srcStep,
Ipp* pDst, int dstStep, IppiSize roiSize,const Ipp8u* pMask, int
maskStep);
Best Regards
Ying
