Fixed-Accuracy Arithmetic Functions
constantine-vassilev
From the Fixed-Accuracy Arithmetic Functions listed in Vol 1/Signal Processing/Chapter 12 I do not see multiplication, addition and subtraction - do I miss something?
Also I suppose Ipp32f notation which generally means floating point, to be interpred as fixed point in the context of Fixed-Accuracy Arithmetic Functions. Am I correct?
gol
those operations are so basic that it would surely be less efficient to achieve less accuracy, there would be no point
gol
Also, no it's not fixed point, but floating point. Those functions are functions that eat a lot of CPU but can be approximated with less accuracy for less CPU, that's why they are there. Even though there are native instructions to divide, it's still a very slow process, whilethe CPU can do several multiplications per cycle, hence nothing to speed up here.
Quoting - gol
looking at their header files I see all oprations, obviously documentation is not full.
Vladimir_Dudnik
all IPP fnctions should be listed in documentation. Could you please point to which function you did not find reference in IPP manual?
Vladimir
