Fourier transfom in c#
L_Y_
I have been looking for a working example for the fourier transform using IPP in C#. Issue here is most of the example code here don’t work with the IPP version 9.0.
I wrote following code finally but unfortunately no data is assigned to the destination array. What might be the problem here?
And I have real signal and I create a complex signal to apply fft. Is it better to do fft directly using real signal?
Thanks!
using System.Runtime.InteropServices;
using ipp;
namespace IntelIPP_Test
    unsafe public class Program
        // Spec and working buffers
        static IppsFFTSpec_C_32fc* pFFTSpec;
        static byte[] pFFTSpecBuf, pFFTInitBuf, pFFTWorkBuf;
        // Allocate complex buffers
        static Ipp32fc[] pSrc, pDst;
        // Query to get buffer sizes
        static int _sizeFFTSpec, _sizeFFTInitBuf, _sizeFFTWorkBuf;
        //Set the size
        static int N = 128;
        static int order = (int)(Math.Log10((double)N) / Math.Log10(2.0));
        static void Main(string[] args)
            int ippDivisionAlgorithm = 8; // (int)sp.IPP_FFT_DIV_INV_BY_N;
            IppHintAlgorithm ippPerformanceHint = IppHintAlgorithm.ippAlgHintAccurate;
            IppStatus result;
            fixed (int* sizeFFTSpec = &_sizeFFTSpec, sizeFFTInitBuf = &_sizeFFTInitBuf, sizeFFTWorkBuf = &_sizeFFTWorkBuf)
                result = sp.ippsFFTGetSize_C_32fc(order, ippDivisionAlgorithm, ippPerformanceHint,
                    sizeFFTSpec, sizeFFTInitBuf, sizeFFTWorkBuf);
            // Alloc FFT buffers
            pFFTSpecBuf = new byte[_sizeFFTSpec];
            pFFTInitBuf = new byte[_sizeFFTInitBuf];
            pFFTWorkBuf = new byte[_sizeFFTWorkBuf];
            // Initialize FFT
            fixed (byte* p_dftInitBuf = pFFTInitBuf)
            fixed (byte* p_dftSpecBuf = pFFTSpecBuf)
                var p_dftSpec = (IppsFFTSpec_C_32fc*)pFFTSpec;
                result = sp.ippsFFTInit_C_32fc(&p_dftSpec, order, ippDivisionAlgorithm, ippPerformanceHint, p_dftSpecBuf, p_dftInitBuf);
            getData(); // to assign data to pSrc
            fixed (Ipp32fc* pSource = pSrc, pssDst = pDst)
            fixed (byte* p_workBuffer = pFFTWorkBuf)
                var p_dftSpec = (IppsFFTSpec_C_32fc*)p_dftSpecBuf;
                // Fast Forward Fourier to spectra domain
                sp.ippsFFTFwd_CToC_32fc(pSource, pssDst, p_dftSpec, p_workBuffer);
Ying_H_Intel
Hi L.Y.
You mentioned, most of the example code here don’t work with the IPP version 9.0.  I recalled there is some C# sample in previous version, do you mean them?
I search them, include MKL C# sample,  it seems no FFT sample,
https://software.intel.com/en-us/articles/using-intel-mkl-in-your-c-program
Could you attach the small test case, so I can debug directly?
Best Regards
Ying
L_Y_
Hi Ying,
Thanks for your response. Actually, I used "here" in context of Intel IPP forum. I have searched through forum using "c# fft" and "c# fourier" keywords and evaluated the codes found. For example:
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/306767
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/304898
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/309242
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/309240
All examples use "ippsFFTInitAlloc_R_32f" for initialization. I have written finally following codes for the fft of real signal.
    unsafe public class program3
        static byte[] fFTSpecBuf, fFTInitBuf, fFTWorkBuf;
        static int sizeFFTSpec, sizeFFTInitBuf, sizeFFTWorkBuf;
        static IppsFFTSpec_R_32f ppFFTSpec2 = new IppsFFTSpec_R_32f();
        //Set the size
        static int N = 8;
        static float[] h = { 1.0f / 3, 1.0f / 3, 1.0f / 3, 0, 0, 0, 0, 0 };
        static float[] x = new float[8];
        static float[] X = new float[8];
        static float[] H = new float[8];
        public static void Main()
            // initialize status
            IppStatus st;
            int ippDivisionAlgorithm = 4;
            fixed (int* p_sizeFFTSpec = &sizeFFTSpec, p_sizeFFTInitBuf = &sizeFFTInitBuf, p_sizeFFTWorkBuf = &sizeFFTWorkBuf)
                st = sp.ippsFFTGetSize_R_32f(N, ippDivisionAlgorithm, ippPerformanceHint, p_sizeFFTSpec, p_sizeFFTInitBuf, p_sizeFFTWorkBuf);
            fFTSpecBuf = new byte[sizeFFTSpec];
            fFTInitBuf = new byte[sizeFFTInitBuf];
            fFTWorkBuf = new byte[sizeFFTWorkBuf];
            // Initialize FFT
            fixed(IppsFFTSpec_R_32f* ppFFTSpec = &ppFFTSpec2)
            fixed (byte* p_fftInitBuf = fFTInitBuf)
            fixed (byte* p_fftSpecBuf = fFTSpecBuf)
                IppsFFTSpec_R_32f* _ppFFTSpec = (IppsFFTSpec_R_32f*)ppFFTSpec;
                st = sp.ippsFFTInit_R_32f(&_ppFFTSpec, N, ippDivisionAlgorithm, ippPerformanceHint, p_fftSpecBuf, p_fftInitBuf);
            fixed(IppsFFTSpec_R_32f* pSpec3 = &ppFFTSpec2)
            fixed (byte* p_FFTWorkBuf = fFTWorkBuf)
            fixed (float* px = x, pX = X, ph = h, pH = H)
                IppsFFTSpec_R_32f* _ppFFTSpec = (IppsFFTSpec_R_32f*)pSpec3;
                st = sp.ippsSet_32f(3.0f, px, 8);
                x[3] = 5.0f;
                st = sp.ippsFFTFwd_RToCCS_32f(px, pX, _ppFFTSpec, null);
                st = sp.ippsFFTFwd_RToPerm_32f(px, pX, _ppFFTSpec, null);
                st = sp.ippsFFTFwd_RToPack_32f(px, pX, _ppFFTSpec, null);
                //________________________
                st = sp.ippsFFTFwd_RToCCS_32f(ph, pH, _ppFFTSpec, null);
                st = sp.ippsFFTFwd_RToPerm_32f(ph, pH, _ppFFTSpec, null);
                st = sp.ippsFFTFwd_RToPack_32f(ph, pH, _ppFFTSpec, null);
                st = sp.ippsMulPack_32f_I(pH, pX, 8);
                st = sp.ippsFFTInv_PackToR_32f(pX, px, _ppFFTSpec, null);
At the end of the code, I would like to try different kind of conversions (ippsFFTFwd_RToCCS_32f, ippsFFTFwd_RToPerm_32f, ippsFFTFwd_RToPack_32f). However, I get following error as status for all cases: "ippStsContextMatchErr". I would be grateful if you can have a look at my code. And other issue is using of "ippsFree" which I couldn't find a way to make it work.
L.Y.
