H.264 Decoder failed
yida_123
Hello
i used h.264 decoder sample to decode a packet. the emergence of a gray section, how to solve this problem? I used the ffmpeg solution of this package, there is no such phenomenon.
who can help me ?
by the way , 352*288 is right, but 1280*720 has that problem.
i used ipp_ia32_5.3 , and ipp-samples 5.3
Emmanuel_W_
Quoting - yida123
hi
IF i want to use ipp , is there any solutions ? and how should i do
yida
In umc_h264_slice_decoding.h there is a function called IsPictureTheSame.
Toward the end of the function there is a check done to compare the idr_pic_id of two slices.
If you comment out the check (and following return) you will be able to decode the stream.
Note that if you do so the decoder will be unable to differentiate between two consecutives IDR that have missing packets.
Emmanuel
Vladimir_Dudnik
IPP 5.3 is a bit out dated version. Is there any chance to check this with the latest version which is IPP 6.1 update 1?There wereseveral bug fixed since IPP 5.3...
Vladimir
PaulF_IntelCorp
Hello Yida,
Significant improvements and bug fixes have been implemented since v5.3 was released (current version is v6.1.1). Please upgrade your IPP library to see if that fixes the problem you are experiencing. Your upgrades to 6.1 will be free if your subscription is still active (generally, if you purchased your product withing the last year). Log into the registration center to determine the state of your license:
A subscription renewal can be purchased for less cost than repurchasing the product, to extend your license (please note the difference between a subscription renewal and a new purchase as covered in the FAQ links below).
Paul
yida_123
Hello Yida,
Paul
thanks !
i also used the ipp 6.0, the problem is the same .
is there any different between ipp 6.0 and ipp6.1?
that problem didn't hanppend all the time , Decode some time to appear.
who can help me ?
yida123
Quoting - yida_123
thanks !
who can help me ?
i used ipp 6.1 the problems still existence
is this ipp bug
is there has the Solutions
PaulF_IntelCorp
Can you provide some sample video files that illustrate the problem?
yida123
HiPaul and thanks for the reply,
how can i post to you ?
the packet is so big , 8817kb
Thanks!
yida123
Vladimir
hi vladimir
i just want to know about ipp decode h264, H264 decoding process, if there are 2 consecutive bytes of 0, there will be an 0x03, I want to know whether to delete the 0x03when use ipp decoding
PaulF_IntelCorp
Quoting - yida123
Thanks!
When you reply to a post in the forum there is an "Add Files" button (above the editing window) where you can attach a file along with your reply. Not sure how big the attachments can be, but please give it a try. If that doesn't work we can find an alternate method. I think the file is too large to mail (will probably bounce).
yida123
hi paul
the 264 packet decoded by ffmpeg is correctly.
yida123
hi paul
Can you see the files , is there some problem?
yida
Emmanuel_W_
Quoting - yida123
hi paul
yida
Hi Yida,
There seem to be a problem in the stream. Toward the beginning there are two IDRs which both have an invalid intra chroma mode at MB 720 which cause the decoder to throw an exceptions (you can get more details by putting a breakpoint into the constructor ofh264_exception).
On my side the file would not decode at all until I modified the functionProcessSegment in umc_h264_segment_decoder_mt.cpp to return a success code instead of an error in case of an exception.
I get a video of an office with the top broken (green band)
Emmanuel
yida123
Quoting - eweber
Hi Yida,
Emmanuel
Hi Emmanuel
Thanks for your reply!
That ismy problem . iget the video of an office with the top broken(gray band). but when i used ffmpeg decode ,the video is correct.
Yida
Emmanuel_W_
Quoting - yida123
Hi Emmanuel
Yida
Hi yida,
The problem is in the stream, ffmpeg makes an assumption (which is working in that case). The idr_pic_id field of frame 78 is 36 for the first slices and then becomes 35 begining with the slice with MB address 720. According to the specs all slices of the IDR should have the same value. The IPP decoder treat it as two different frames, ffmpeg probably do not check the value and assume it is the same frame. (not that both my analyser and reference implementation show that frame broken and actually have the exact same output than my IPP implementation).
Emmanuel
yida123
Quoting - eweber
Hi yida,
Emmanuel
Hi Emmanuel,
Thanks for your reply. is there exactly solution.modify the frame by myself? i received the data from network.
can you show me the code?
yida
yida123
hi
yida
Emmanuel_W_
Quoting - yida123
hi
yida
Emmanuel
yida123
Quoting - eweber
Emmanuel
Hi Emmanuel,
Thanks for your reply! The problem had solved !
Thanks so much!
yida
