6847 Discussions
H.264 Encoder getting Access violation error during GetFrame function call
Bhanuprakash-reddy
I have getting access violation error in memcopy.asm file during a function call H264VideoEncoder::GetFrame(MediaData *in, MediaData *out) for encoding a specific frame.
I got a Access violation error below palce in memcopy.asm file,
LeadUp2:
and edx,ecx ;U - trailing byte count
mov al,[esi] ;V - get first byte from source
mov [edi],al ;U - write second byte to destination -----------> Access violation error
mov al,[esi+1] ;V - get second byte from source
Bhanuprakash.
Ying_H_Intel
Hello Bhanuprakash,
What platform and Which IPP sample version are you using? Are you call it from mulithreads? It is better if you canprovide a piece of input frame (YUV file andinput parameter)for us to see what is the problem.
Here is a sample h.264 encoder main.cpp<<http://software.intel.com/en-us/articles/getting-started-with-intel-ipp-unified-media-classes-sample/> for your reference.
Ying
Ying_H_Intel
Hello Bhanuprakash,
Ying
Bhanuprakash-reddy
Hi Ying,
I have solved my problem referring with intel-ipp-unified-media-classes-sample which you are provided.
Previously I createdDataOut Object like below:
MediaData *m_pMediaOut = NULL;
if( m_pMediaOut == NULL)
m_pMediaOut = new MediaData();
m_pMediaOut->Alloc(4*m_nWidth*m_nHeight); // this line of code created problem
after that I changed to m_pMediaOut->SetBufferPointer(chEncodedData,nWidth*nHeight);
My Sample code is like below:
int CH264Codec::EncodeData(unsigned char *chYUVData,int nWidth, int nHeight, int nYUVSize, unsigned char *chEncodedData)
if(chYUVData == NULL)
return 0;
m_nEncodedSize = 0;
try
UMC::Status ret = UMC_OK;
if(m_pEncoderParams && m_pVideoIn )
ret = m_pVideoIn->SetBufferPointer(chYUVData,nYUVSize);// It is for streaming data
m_pVideoIn->SetDataSize(nYUVSize);
m_pVideoIn->SetTime((m_nFramesEncoded+1)/m_pEncoderParams->info.framerate);
m_pEncoderParams->numEncodedFrames = m_nFramesEncoded;
m_pCodec->SetParams(m_pEncoderParams);
m_nFramesEncoded++;
if( m_pCodec && m_pVideoIn && m_pMediaOut )
ret = m_pCodec->GetFrame(m_pVideoIn, m_pMediaOut);
if ( (ret != UMC_OK) && (ret != UMC_ERR_NOT_ENOUGH_DATA) && (ret != UMC_ERR_END_OF_STREAM))
logger.Print(LL_INTERR, PANLOG("H264 encoding failed\n"));
m_pVideoIn->ReleaseImage();
m_pVideoIn->Reset();
m_pMediaOut->Reset();
return UMC_ERR_FAILED;
if ( ret == UMC_OK )
m_nEncodedSize = (Ipp32s)m_pMediaOut->GetDataSize();
catch(...)
logger.Print(LL_INTERR, PANLOG("[CH264Codec::EncodeData] Exception - Error: %ld\n"), GetLastError());
return m_nEncodedSize;
