6832 Discussions
Error running hvOpenCV (handvu-beta3 + OpenCV 2.1.0 + Ubuntu 10.04)
fcedillo
I have downloaded and compiled HandVu donwloaded from Moves Institute, that is handvu-beta3.tar.gz.
After extracted i got handvu-beta3 directory. Then compiled it on Ubuntu following instructions on Ubuntu Forums.
I am using OpenCV 2.1 downloaded from SourceForge that is OpenCV-2.1.0.tar.bz2. This is the current version as indicated on OpenCV web on Willow Garage.
Inside handvu-beta3 there is hv_OpenCV directory and these files are located there:
  • hvOpenCV
  • hv_OpenCV.cpp
  • hv_OpenCV.o
  • hv_OpenCV.vcproj
  • Makefile
  • Makefile.am
  • Makefile.in
When I execute this command: ./hvOpenCV 0
This is the output:
will load conductor from file:
0
Hot keys:
ESC - quit the program
r - restart the tracking
0-3 - set the overlay (verbosity) level
use the mouse to select the initial detection area
error with file 0:
could not find or open file
error with file 0:
note: paths in VisionConductor files are relative;
in this case to /media/Files/files/downloads/web/OpenCV/HandVu/handvu-
beta3/hv_OpenCV
OpenCV Error: Unspecified error (error with file 0:
beta3/hv_OpenCV) in hvLoadConductor, file HandVu_Cintf.cpp, line 161
terminate called after throwing an instance of 'cv::Exception'
Aborted
Could anyone help me?
Ying_H_Intel
Hi fcedillo,
Inever tried the handvu package. But see from the command output
error with file 0:
error with file 0:
The commandis expecting a input file. So you may check if there is any documentation about how to run the exectuale ./hvOpenCV. Maybeit require other parameter, beside of "0". Or you can check the code in hv_OpenCV.cpp?
Ying
fcedillo
Needed to execute
$./hvOpenCV ../config/default.conductor
Detail was in parameters, the program can be executed with parameters to indicate camera, video and configuration file.
Thank you very much Ying H :)
