6814 Discussions
H.264 UMC encoder: non-IDR I frame is generated, even when idr_interval is set to 1
IDZ_A_Intel
I'm using IPP 6.1 with the lastest update.
I wrote a program that uses your UMCH.264 encoder and I found that sometimes it generates non-IDR I frames, even I set the H264EncoderParams::key_frame_controls.idr_interval to 1.
My parameters are like this:
params->chroma_format_idc = 1;
params->profile_idc = H264_BASE_PROFILE;
params->entropy_coding_mode = 0;
params->B_frame_rate = 0;
params->coding_type = 0;
params->mv_search_method = 6;
params->me_split_mode = 0;
params->me_search_x = params->me_search_y = 8;
params->deblocking_filter_idc = 0;
params->num_ref_frames = 1;
params->rate_controls.method = H264_RCM_VBR;
params->rate_controls.quantI = 20 - (quality_ - QUALITY_STANDARD) * 3;
params->rate_controls.quantP = 32 - (quality_ - QUALITY_STANDARD) * 3;
params->rate_controls.quantB = 50;
params->info.bitrate = 0;
params->key_frame_controls.method = H264_KFCM_INTERVAL;
params->key_frame_controls.interval = keyInterval_;
params->key_frame_controls.idr_interval = 1;
My application requires that all I-frames must be decoded by itself (i.e. all I frames must be IDR frame)
In my knowledge, to make an I frame an IDR frame, setting idr_interval to 1 is all I have to do.
But with this setting, UMC encoder sometimes generates non-IDR I frame.
H264CoreEncoder_Encoder function in umc_h264_gen_enc_tmpl.cpp.h ,
switch (ePictureType) {
case INTRAPIC:
if (core_enc->m_pCurrentFrame->m_bIsIDRPic || core_enc->m_uFrames_Num == 0) {
// Right now, only the first INTRAPIC in a sequence is an IDR Frame
ePic_Class = IDR_PIC;
core_enc->m_l1_cnt_to_start_B = core_enc->m_info.num_ref_to_start_code_B_slice;
} else {
ePic_Class = REFERENCE_PIC;
break;
Sometimes ePic_Class becomes REFERENCE_PIC(non-IDR frame, right?)and this I frame cannot be decoded solely.
Please let me know - Is my parameter wrong? or something is wrong in IPP UMC sample?
stoh
Ying_H_Intel
Just for your reference,
the dicussion in http://software.intel.com/en-us/forums/showthread.php?t=79567&o=a&s=lrseems similiar.
Ying
Ying_H_Intel
One additional notes , for make sure each I frame become IDR frame, youmaymodifythis condition
case INTRAPIC:
// if (core_enc->m_pCurrentFrame->m_bIsIDRPic || core_enc->m_uFrames_Num == 0)
if (core_enc->m_pCurrentFrame->m_bIsIDRPic || core_enc->m_uFrames_Num == 0 || core_enc->m_info.key_frame_controls.idr_interval == 1)
Happy new year!
Best wishes,
Ying
