H.264 and RTP
lrogersego
Hey gang,
I am encoding and decoding using 264 sample 320x240 video. I need to be able to now split up and join together rtp-based packets. Is there a simple way of doing this using IPP libs and/or samples? If you have a place I can start poking around, let me know. Thank you
/Loren
lrogersego
Quoting - lrogersego
Hey gang,
/Loren
I was under the impression this was a good place to get help from Intel. Guess I was wrong
matt_fisher
Hi.
Since no one has responded, I'll answer your question. I did not find anything in the sample code to handle rtp packets, so I wrote my own implementation of rfc3984. However, this wasover two years ago so things maybe different now. But don't be discouraged. If you only have to deal with the Single NAL Unit case (and perhaps fragmentation units), it is trivial. What is your application? Most H.323 endpoints I've seen only send single NAL units. Take a look at rfc3984. You will be okay.
Emmanuel_W_
Hey gang,
/Loren
If you can't split up NALs over multiple RTP packets you need to make sure your NAL fit in one packet. I do not think this can be achieve easily in the current sample. You can increase the number of slices but then you might end up with plenty of tiny packets which is not very efficient.
The way out is to generate slices on the fly as you are encoding your frame. This requires somere-factoringof the IPP sample.
Emmanuel_W_
The latest H.264 encoder sample that comes with IPP 6 support a notion of maximum slice size which should do the trick.
