6847 Discussions
H.264 stream receiving, but decode problem Help!!!!
vikas_krv85
Dear Sir/Madam,
Please help, we require urgently
We get mpeg4 and h264 stream from ip cam, remove RTP headers, and pass to UMC
Only Mpeg4 strream is getting decoded and displayed properly, but when h264 stream is given for decoding ,italways returns -996 UMC_ERR_NOT_ENOUGH_DATA
please find the attached stream file
My Code is given below
Ipp32s width=320,height=240;
UMC::ColorFormat color_format=UMC::YV12;
UMC::MPEG4VideoDecoder *mpeg4Decoder ;
UMC::H264VideoDecoder *h264Decoder;
UMC::VideoDecoderParams *params ;
UMC::MediaData *pIn;
UMC::VideoData *pOut ;
mpeg4Decoder = new UMC::MPEG4VideoDecoder();
h264Decoder = new UMC::H264VideoDecoder();
params = new UMC::VideoDecoderParams();
pIn = new UMC::MediaData;
pOut = new UMC::VideoData;
//this function gets called for each frame(I/P/B) received
void Buffer(char *szData, int nLen)
if(!g_bInit)//first frame initialize
g_bInit = true;
pIn->SetBufferPointer((Ipp8u *)szData,nLen);
pIn->SetDataSize(nLen);
params->m_pData = pIn;
//if (UMC::UMC_OK != (mpeg4Decoder->Init(params))) MPEG Decoder stream is working
////Process errors
if (UMC::UMC_OK != (h264Decoder->Init(params)))
//Process errors
pOut->Init(width, height, color_format);
pOut->Alloc();
// Decoding stream using GetFrame(pIn, pOut) method
//UMC::Status stRes = mpeg4Decoder->GetFrame(pIn,pOut);
UMC::Status stRes = h264Decoder->GetFrame(pIn,pOut);//always returns -996 ie UMC_ERR_NOT_ENOUGH_DATA
if(UMC::UMC_OK == stRes)
((CRTSPappDlg*)g_hWnd)->staticDisplay.DisplayImage((BYTE*)pOut->GetDataPointer(),width,height,24,"");// this code displays the frame
SaveImage((BYTE*)pOut->GetDataPointer(),width,height,24);//this save to bmp file
//delete mpeg4Decoder; //destructor automatically calls Close() method.
//delete h264Decoder; //destructor automatically calls Close() method.
Please help!!!!!!
thanks in advance
vikas_krv85
When i use simple_player and play the attached file, it just prints
Stream Type : H264PV
and exits the application, notdecoding the video
Please help!!!!!
Vladimir_Dudnik
thanks for reporting the issue (and attaching test file). Could you please also specify what version of IPP and audio-video-codecs sample do you use?
Vladimir
vikas_krv85
IPP Version - 5.3.3.082
Samples : w_ipp-samples_p_5.3.095
Please help !!!!! urgent
Vladimir_Dudnik
Well, you are using the previous version of IPP. Could you please check this issue on the latest, IPP 6.0 release?
Vladimir
vikas_krv85
Sorry for the trouble guys
Got h264 stream up and running
Problem was SPS and PPS was missing, so later found it from SDP , parsed and added to stream data and was able to get live display
thanks
Vladimir_Dudnik
Thanks for updating us on this. In any case I would recommend you to evaluate the latest IPP version.
Vladimir
