H264VideoEncoder problem to process GetFrame
stsybikov
Hi Intel Gurus,
I have the problem with H264VideoEncoder to encoder the file with smaller resolution size rather than original frame data size.
I have YUV420 1920x1080 buffer with data and the sample of my code:
UMC::Videodata DataIn;
UMC::MediaData DataOut;
Int FrameSize;
UMC::H264EncoderParams Params;
UMC::H264ViveoEncoder H264Encoder;
Params.key_frame_control.method = 1;
// If I have define width as 1920 and height as 1080 everything works great,
// If define a different width and height H264Encoder.GetFrame(…) crashes pointing to the memory allocation.
Params.info.clip_info.height = height;
Params.info.clip_info.width = width;
Params.info.bitrate = 10000000;
Params.info.framerate = 24;
Params.numThreads = 1;
H264Encoder.Init(&Params);
FrameSize = FrameWidth*Frameheight*3/2; //1920*1080*3/2
Ipp8u* pOutputData = ippsMalloc_8u(FrameSize);
DataIn.Init(FrameWidth, Frameheight, UMC::YUV420, 8); // 1920, 1080
DataIn.SetBufferPointer(pYUVFrameBuffer, FrameSize);
DataIn.SetDataSize(FrameSize);
DataOut.SetBufferPointer(pOutputData,10000000);
H264Encoder.GetFrame(&DataIn, &DataOut);  // the code crashes in this point
Any idea why H264Encoder crashes ??????????????
Sergey Tsybikov
Smith&Nephew Endoscopy
stsybikov
I found the solution for this issue from answer on my other post: http://software.intel.com/en-us/comment/1715029#comment-1715029 Sergey Tsybikov
