6847 Discussions
Help: How to use the Polyphase analysis Filterbank function of the ipp
ngurom
Hello Im R.Nguete,
I want to split an input signal into 32 Suband. to achieve it, im using the polyphase Analysis Filterbank functions from the ipps library.
I write this small code but it not work corretly because after calling the main function (ippsAnalysisFilter_SBR_RToC_32f32fc_D2L) i receive "ippStsContextMatchErr" error. Please can somebody help me to know what it wrong in my source?
IppStatus ippRes;
Ipp32s pSizeSpec, pSizeInitBuf, pSizeWorkBuf;
Ipp32fc* pDst[32];
int iChannel = 32;
IppsFilterSpec_SBR_C_32fc** ppFilterSpec;
Ipp8u* pMemSpec;
Ipp8u* pInitBuf;
Ipp8u* pWorkBuf;
int NumLoop= NUM_TIME_SLOTS * RATE;// = 16*2 = 32
int offset = SBR_TIME_HFGEN ; // 8 siehe (sbr_dec_settings.h)
int kx = 0; //first Subband 0<=kx<=32
// get size need for the analysisfilter
ippRes = ippsAnalysisFilterGetSize_SBR_RToC_32f32fc(&pSizeSpec,&pSizeInitBuf,&pSizeWorkBuf);
if (ippRes != ippStsOk)
printf("error during getsize for the Analysis Filter");
return 1;
// Memory allocation
pInitBuf = (Ipp8u*)calloc(1,pSizeInitBuf);
pWorkBuf = (Ipp8u*)calloc(1,pSizeWorkBuf);
// Ipp8u* pAnalysisFilterSpec[2];
pMemSpec = (Ipp8u*)calloc(1,pSizeSpec);
ppFilterSpec = (IppsFilterSpec_SBR_C_32fc**)calloc(iChannel,sizeof(IppsFilterSpec_SBR_C_32fc*));
for (int i=0;i {
if(pSizeSpec !=0)
ppFilterSpec =(IppsFilterSpec_SBR_C_32fc*)calloc(1,pSizeSpec);
else
ppFilterSpec = NULL;
ippRes = ippsAnalysisFilterInit_SBR_RToC_32f32fc(ppFilterSpec,pMemSpec,pInitBuf);
printf("error during initilaisation for the Analysis Filter");
return 1;
//Filtering
ippRes = ippsAnalysisFilter_SBR_RToC_32f32fc_D2L((constIpp32f*)pSrc->DataPtr(),pDst,SBR_TABLE_QMF_WINDOW_320,
NumLoop,offset,kx,ppFilterSpec[5],pWorkBuf);
printf("error during filtering for the Analysis Filter");
return 1;
Thanks you
R. Nguete
Chao_Y_Intel
Hi Nguete,
It looks that the initiation is not correct. It need to initiate each of the filter:
for (int i=0;iippRes = ippsAnalysisFilterInit_SBR_RToC_32f32fc( &(ppFilterSpec),...);
Chao
ngurom
Quoting - Chao Yu (Intel)
Hi Nguete,
Chao
Hi Chao,
Thanks for your Answer to my question. I initialize all subband filter as your write me on the last post. But now i meet that there are all point to the same reference and in in the filtering step (by calling:ippsAnalysisFilter_SBR_RToC_32f32fc_D2L() ) I receive an Access violation error . may be you can tell have another idea, or is it posible to send me a small example of the implementation of this polyphase analysis filterbank?
this is my new code:
IppStatus ippRes;
Ipp32fc* pDst[32];
int iChannel = 32;
Ipp8u* pMemSpec;
Ipp8u* pInitBuf;
Ipp8u* pWorkBuf;
return 1;
int i =0;
for (i=0;i {
if(pSizeSpec !=0)
else
for (i=0;i {
ippRes = ippsAnalysisFilterInit_SBR_RToC_32f32fc( &(ppFilterSpec),pMemSpec,pInitBuf);
pDst = ( Ipp32fc*)calloc(pSrc->Length(),sizeof(Ipp32fc));
// ippRes = ippsAnalysisFilterInit_SBR_RToC_32f32fc(ppFilterSpec,pMemSpec,pInitBuf);
return 1;
//Filtering
ippRes = ippsAnalysisFilter_SBR_RToC_32f32fc_D2L((const Ipp32f*)pSrc->DataPtr(),pDst,SBR_TABLE_QMF_WINDOW_320,
NumLoop,offset,kx,*ppFilterSpec,pWorkBuf);
return 1;
return 0;
Thanks you !
R.Nguete
Chao_Y_Intel
please checkthe notes from our AAC expert on the problem:
The following are the working code. For every call of ippsAnalysisFilter_SBR_RToC_32f32fc_D2L function, 1024 samples of Src data are processed. note that offset first pDst pointers will be skipped, so the first pointer to actual dst data is pDst[offset]. Also all subbands begins from kx are cleared.
for(i = offset, i < NUM_TIME_SLOTS * RATE + offset; i++)
for (j = kx; j < 32; j++)
pDst = 0;
IppStatus ippRes;
Ipp32fc* pDst[NUM_TIME_SLOTS * RATE + SBR_TIME_HFGEN];
Ipp32f src[1024];
IppsFilterSpec_SBR_C_32fc* pFilterSpec;
Ipp8u* pMemSpec;
Ipp8u* pInitBuf;
Ipp8u* pWorkBuf;
int kx = 31; //first SBR Subband 0<=kx<32
int i;
&pSizeInitBuf,
&pSizeWorkBuf);
return 1;
for (i=0;i<(NumLoop + offset);i++)
pDst = (Ipp32fc*)calloc(32,sizeof(Ipp32fc));
ippRes = ippsAnalysisFilterInit_SBR_RToC_32f32fc(&pFilterSpec,pMemSpec,pInitBuf);
return 1;
//Filtering
pWorkBuf);
return 1;
return 0;
