How can I build the Ipp WinCE samples code
loca_huang
Hi:
What is the software and hardware requirements if I want to build the buildwcex86.bat and buildwcearmv4i.bat?
I can build build32.bat but can not build other batch files....
regards
Vladimir_Dudnik
Sorry if this information is missed in sample's readme.htm file. You need to have Microsoft Embedded Visual Studio v4.2 with Service Pack 2 and Pocket PC 2003 SDK installed in order to be able to compile this sample.
Vladimir
newbie2009
Vladimir
I'm working now on WinXP Professional.
I do have eVC 4 installed, as well as SP4.
I also have Pocket PC 2003 SDK installed,
I browsed to My Computer -> Properties ->Advanced->Environment Variables, and I included two new variables in both, user variables and system variables: IPPROOT = C:Program FilesIntelIPP5.3.3.082ia32 and SDKROOT = C:Windows CE Tools
Then I brow3sed to C:ipp-samplesspeech-codecs, and I ran buildwcex86.bat
The command prompt window appeared, ran the code, and closed. Then I browsed to C:ipp-samplesspeech-codecsbinwcex86_lib but I did NOT find the usc.lib file I was supposed to get.
Is there any step that I missed the procedure to build IPP for WinCE?
Regards.
newbie2009
Quoting - newbie2009
Regards.
After further inspection, I noticed that the compiler can't open header files such as stdlib.h and stdio.h
The errors are mainly generated in the source files within C:ipp-samplesspeech-codecsapplicationusc_speech_codecsrc
Why? Am I missing any step to get the build done?
Regards.
newbie2009
Vladimir
Regards.
I found my problem.
I changed SDKROOT to C:Program FilesWindows CE Tools and it worked.
