Subject is the question, How do you use ippsDeflateHuff_8u with ippsDeflateLZ77_8u?
I presume you use ippsDeflateLZ77_8u first, then ippsDeflateHuff_8u but I don't see any in-between function to build the Huffman Tables?
Is there a clean example of just compressing one buffer of data using LZ77 with Huffman Encoding?
I found ippsDeflateLZ77FastestGenHuffTable_8u which seems to work.
Although I finally figured out how to use the latest version, it turns out it's much slower than Version 7. The tests I did with the old ipp_zlib took 8 seconds, with the new one it took 18 seconds, also the raw compression not using zlib, the old took 6 seconds (and compressed more) vs the new which takes 8 seconds (and compressed less). It was consistent so I'll just stick with the old stuff.
Please share out your reproducers for the performance gaps, Including share the Software, OS, and Hardware information
