How to Grad Frames From Mpeg By OpenCV
walkerwoo
Seems it only work with AVI. However, my job requires me to do real-time processing of the mpeg. Any libraries combined with openCV?
Woo
Vladimir_Dudnik
Hi
you can use UMC infrastructure (IPP media sample). I think you will need to convert UMC VideoData frame to image format used by OpenCV.
Vladimir
walkerwoo
Actually, Because I need to read mpeg directly(for real-time processing), so maybe what I need is a library linked with OpenCV. Any other tips? Thanks.
Woo.
Vladimir_Dudnik
No other tips from me. You may ask the same question at OpenCV forum.
Vladimir
dimarok1
Quoting - walkerwoo
Woo.
I need also to read mpeg directly, walkerwoo did you manage to find a solution ?
Or anyone else can help me ?
Vladimir_Dudnik
Did you notice highgui library in OpenCV? It should be able to process MPEG files..
Vladimir
dimarok1
Vladimir
I included that library but it didn't work. avi files works really fine but when I try to read and show an mpeg file into a window, nothing happen...
Thanks anyway
