How to build a reflective border of a matrix?
guang_c
I have a matrix A of size mxn. I would like to make a reflective border around the boundary of matrix A. Could you please let me know how to do it by using Intel IPP?
Thank you very much,
Guangyi Chen
SergeyKostrov
Valued Contributor II
>>...matrix A of size mxn...
It's clear.
>>...a reflective border around the boundary of matrix A...
Sorry, I didn't understand your question. What is a reflective border?
Do youwant to do somethingwith a matrix usingclassic Reflection Operations of theLinear Algebra?
igorastakhov
New Contributor II
if it's about image processing - you can use the next functions:
// Name: ippiCopyReplicateBorder
// Purpose: Copies pixel values between two buffers and adds
// the replicated border pixels.
// Returns:
// ippStsNullPtrErr One of the pointers is NULL
// ippStsSizeErr 1). srcRoiSize or dstRoiSize has a field with negative or zero value
// 2). topBorderHeight or leftBorderWidth is less than zero
// 3). dstRoiSize.width < srcRoiSize.width + leftBorderWidth
// 4). dstRoiSize.height < srcRoiSize.height + topBorderHeight
// ippStsStepErr srcStep or dstStep is less than or equal to zero
// ippStsNoErr OK
// Parameters:
// pSrc Pointer to the source image buffer
// srcStep Step in bytes through the source image
// pDst Pointer to the destination image buffer
// dstStep Step in bytes through the destination image
// scrRoiSize Size of the source ROI in pixels
// dstRoiSize Size of the destination ROI in pixels
// topBorderHeight Height of the top border in pixels
// leftBorderWidth Width of the left border in pixels
// Name: ippiCopyConstBorder
// the border pixels with constant value.
// Returns:
// ippStsNoErr OK
// Parameters:
// srcRoiSize Size of the source ROI in pixels
// value Constant value to assign to the border pixels
// Name: ippiCopyWrapBorder
// Purpose: Copies pixel values between two buffers and adds the border pixels.
// Returns:
// ippStsNoErr OK
// Parameters:
Igor
Igor_B_Intel1
Border pixels reflection is a "mirror" border type in IPP. Imagine we've got vector of the len 5 with elements: "1 2 3 4 5" and we whould like to get mirrororedborder in the lenght of 2. Then in result of it we obtain vector in the len of 9 with the elements "3 2 1 2 3 4 5 4 3". So in case of matrixes you need to relflect every row, then reflect every column.
SergeyKostrov
>>...relflect every row, then reflect every column...
- Use ippiCopyReplicateBorder for rows
- Transpose a matrix
In case of a matrixcould itbe done in this way?
igorastakhov
New Contributor II
ippiCopyReplicateBorder does replication both for columns and rows - no need to perform transposition
Igor
SergeyKostrov
How does it deal withcorners of the matrix?
If a length is 2 at every corner there are 4values ( 2x2 block )and I wonder how these values will
be calculated?
Sergey
Igor_B_Intel1
Please note, that this function replicates boundary pixels: not reflects them. Let the input matrix 2x2 will be the following:
1 2
34
And we would like to get border in the length of 1. So after this function call you will get the following 4x4 matrix:
1 12 2
1 12 2
334 4
334 4
SergeyKostrov
Thank you, Igor! This is exactly what I wanted to understand:
All corner values in the new matrixare replicated, not calculated.
Sergey
