6814 Discussions
How to compress 411 three plane image to JPEG?
yaybblfh
I use IPP version 5.3
My code based on c:\Program Files\Intel\IPP\5.3\ia32\ipp-samples\image-codecs\jpegview,
CJPEGEncoder class.
parameters:
m_RestartInterval(0),m_HuffmanOpt(0),m_Mode(JPEG_BASELINE),m_Color(JC_YCBCR),
m_Sampling(JS_411),m_Precision(8),m_Channels(3)
My calls:
Ipp8u* ppSrc[4];
ppSrc[0] = pSrc;
ppSrc[1] = ppSrc[0] + m_Size.width * m_Size.height;
ppSrc[2] = ppSrc[1] + m_Size.width * m_Size.height / 4;
int pSrcStep[4];
pSrcStep[0] = m_Size.width;
pSrcStep[1] = m_Size.width / 4;
pSrcStep[2] = m_Size.width / 4;
JERRCODE jerr = SetSource(ppSrc, pSrcStep, m_Size, m_Channels, m_Color, m_Sampling, m_Precision);
jerr = m_MemBuffOutput.Open(m_pBuf, m_Size.width * m_Size.height);
jerr = SetParams(m_Mode, m_Color, m_Sampling, m_RestartInterval, m_HuffmanOpt, m_Quality);
jerr = WriteHeader();
jerr = WriteData();
All results are OK. But JPG image is incorrect:
My
Vladimir_Dudnik
We will check this. By the way, I do not see attached image (please review 'How to attach file to the forum post' message)
Vladimir
Sergey_Ryadno
first of all, why you determine source image steps such as
i think it must be
pSrcStep[1] = m_Size.width / 2;
pSrcStep[2] = m_Size.width / 2;
Can you also attach source image file?
yaybblfh
Quoting - sryadno
i think it must be
Because my image is:
And result JPG for
is incorrect!
Seesource y411_planar.dat
File format:
DWORD Width;
DWORD Height;
BYTE Y[Wight * Height];
BYTE Cr[Width * Height / 4];
BYTE Cb[Width * Height / 4];
Vladimir_Dudnik
Thanks for clear pictures! It's really helpful. There might be misunderstanding in sampling factors term we use. By historical reason in JPEGwe call 4:1:1 sampling those where chroma planes are downsampled by factor 2 in both horizontal and vertical direction. In video processing world this called as 4:2:0.
We do not support encoding with sampling factors you use.
Vladimir
yaybblfh
Vladimir
Realy! If convert 411 to 420 JPG correct! But why _JPEG_SAMPLING consist 411?
typedef enum _JPEG_SAMPLING
JS_444 = 0,
JS_422 = 1,
JS_244 = 2,
JS_411 = 3,
JS_OTHER = 4
} JSS;
Vladimir_Dudnik
As I said, by historical reasons we still use 4:1:1 name for sampling which frequently called as 4:2:0
Consider this as IPP JPEG specifics.
Vladimir
yaybblfh
Vladimir
And last question. I have 411 pixel format image from videocapture device. But i not found in IPP color convert functions kind of 411 pixel to 420 planar or to 411 planar. What i do?
Many thanks.
Vladimir_Dudnik
Please check through IPP 6.0 ippcc.h and ippiman.pdf files. There are lot of combinations which look like what you expect:
ippiYCbCr420ToYCbCr420_8u_P3P2R
ippiYCbCr420_8u_P3P2R
ippiYCbCr420ToYCbCr411_8u_P3P2R
ippiYCrCb420ToYCbCr411_8u_P3P2R
ippiYCbCr420ToYCbCr411_8u_P2P3R
ippiYCbCr411ToYCbCr420_8u_P3R
ippiYCbCr411ToYCbCr420_8u_P3P2R
ippiYCbCr411ToYCrCb420_8u_P2P3R
ippiYCbCr411ToYCbCr420_8u_P2P3R
Vladimir
