How to create a 'db4' wavelet transform?
lu_h_1
The wavelet transform example uses 'db2' filter which can be find in below link:
https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/308991?wapkw=ippsWTFwd
According to the wavelet transform examples, I get the  'db4' filter values from matlab using wfilters('db4') command.
The length of Lo_D,Hi_D,Lo_R,Hi_R is 8, so I define
static const int fwdFltLenL = 8;
static const int fwdFltLenH = 8;
And copy the values from matlab:
static const float fwdFltL[8] = {-0.0106......};
Other code are the same with the example.
ippsWTFwd_32f (src, low, high, 6, state);
But the low and high values are not equal to the values get by matlab.
So how to create a 'db4' wavelet transform?
Igor_A_Intel
could you be more specific - please provide reproducibles - *.m file for Matlab and *.c(or *.cpp) for IPP - that can be built and executed. And please provide a difference - what is expected and what you see.
Regards, Igor
Shaojuan_Z_Intel
Hi Lu,
Attached please find the examples of creating db2 and db3 wavelet transforms. Creating db4 wavelet transforms should be similar. Thanks!
